I am building a detached garage with a double 2x4 top plate and engineered trusses, 24" OC. At some future date I will insulate and drywall the walls and ceiling, but for now I want to get it wired up in a way that will meet code (Wisconsin Electrical Code, which generally follows NEC 2017) prior to drywall.
I've seen suggestions for running cable along the face of the top plate, but that wouldn't allow me to install drywall later on. Since these are engineered trusses drilling them isn't really an option. Instead I attempted this:
I stapled the cable securely on either side of the truss. Any issues with this approach? I spent quite a while searching the net for pictures or advice, but most answers seemed to address routing around trusses in attics.
