I just replaced an outdoor ceiling fan/light on a gfci circuit, and once we completed the work and re-energized the circuit, my light switch will not move so I can test or turn on the fan. The GFCI breaker in the panelboard operates just fine when I test it. Is there something wired incorrectly or is my switch damaged for some reason?
    Did any breakers trip? how about the GFCI? You might have wired something wrong and shorted out the switch and welded the contacts. – JACK Jun 26 at 22:17
  • I'm confused by your comment "my light switch will not move" - are you talking about a wall switch that supplies power to the fan/light combo, or are you talking about the light switch on the fan itself (I'm thinking of typical cieling fan/light combo units, with separate pull chains to activate either fan or light, or both; and if a wall switch is involved, the wall switch would need to be in the on position in order to test the operation of the fan/light combo). On the other hand, if all you did was replace an existing fan, you wouldn't have need to mess with a wall switch, so it's a mystery – Paul Jun 26 at 22:43
  • JACK, I upvoted your comment. It's probably what happened. – George Anderson Jun 27 at 0:36
