I'm putting in a three-way diverter valve that will supply a rain shower handheld shower or both, similar to this post:
Building new shower, how can I control the flow of water to two different shower heads?
Or similar to this product (referenced in above post): https://www.signaturehardware.com/three-way-in-wall-shower-diverter-lever-handle.html
Is it as simple as plumbing a 1/2" supply to the three-way diverter? Or is there something else I should do to ensure good water pressure/supply when both are in use?
For example, should I get one that has a 3/4" inlet? Or would it be better to just use two totally separate shower fixtures and plumb them with a plumbing loop?
We have very good water pressure in the house an the house is supplied with 3/4" from the city. We're using PEX. I'm a novice at plumbing and I understand enough to plumb a simple bathroom, but this seems advanced and I don't know anything about what problems could arise. I think the problems I should be concerned about are low pressure and water hammer. This is a new bathroom in an old house so it's a remodel but also completely new construction.
Thanks for your help!
  • I'm not sure it's necessary for your fairly simple plan, but could you provide 3/4" lines all the way from the source? – isherwood Jun 25 at 17:06
