I had 2 can lights and three pendant lights about 12" apart over island - they worked fine on the same switch.
I removed the three pendant lights to put in one light fixture that has three light sockets connected to it. This new light has a black and white wire coming through a rod on the left and two black and two white wires coming up the right hand rod (total of six wires), and the ground wire attached to canopy.
The two can lights are first on the line. The first pendant on left, the center pendant and then the pendant on the right (the pendant on right was the end of the line).
I capped off wires from what was the right pendant and connected the new fixture's wires to the wires where the center pendant was hanging connecting all black wires (three from the ceiling and three from the new light fixture and then all white wires in the same manner, and then grounding with all the ground wires.
That did not work! The two can lights still come on, but nothing on the new light.
Obviously, this is not correct. What do I check next and/or redo?
