I installed PPR pipes in my house for water supply and now after investing so much of money and time a person today told me that plastic pipes are not good enough as they burst in freezing temperatures( we live in freezing temperatures and normally it dips 5 degrees Celsius below zero in winters). And also said that if hot water from a geyser(a water boiler) passes through them then the water stinks of the plastic!
From listening to this I'm very anxious and depressed. Has the money been wasted? I've added a picture which has the details written on it, the right one is more detailed. Any help is appreciated. God bless you.enter image description here
16
    Any pipe material can fail if it freezes.... Jun 24 '20 at 3:59
    How close to a geyser do you live that there's a possibility of one erupting through your plumbing? On a more serious note, if you don't smell the plastic when you run hot water now, it's not likely that you will in the future. Also, congrats on including a nice, clear, readable pic in your OP without having to be prompted! It's amazing how many people don't do that...
    Jun 24 '20 at 12:38
    @EdBeal The OP & the pic clearly show PPR on the pipe, but you mention PPE. Are those different pipe types or was that a typo on your part?
    Jun 24 '20 at 12:39
    What does a geyser have do to with this? I'm guessing this is a translation error. In the US, a geyser is a geological structure that regularly erupts hot water (like Old Faithful at Yellowstone NP). Jun 24 '20 at 14:06
    @George Anderson, I meant a water boiler by geyser, I've edited the question. Thank you for pointing it out
    – Kashmiri
    Jun 24 '20 at 14:45
I'd insulate the pipes and move on
PPR, like PEX and unlike PVC, is a freeze-tolerant material; however, that doesn't mean that pipes made from it should be allowed to freeze on a routine basis. I would start by adding pipe insulation (foam pipe insulation is available as prefab, "peel and stick" pieces) provided these are not irrigation pipes, which should be drained/blown out for the winter season anyway. I am baffled as to how you wound up with plumbing runs on the outside of your house, though...
