I have a concrete slab porch that was made into a family room by the previous owner. They used paneling on the walls and I'm going to remove that paneling and replace it with drywall. The top of the wall has wood trim all the way around. That wood is damaged to some extent and I'm thinking of just removing it all. However, that would make the total height for the walls 8ft 8inches. So how should I hang the drywall?
If I take 4x8 sheets, mounted horizontally, I would have 8 inches uncovered. Where should that 8 inches be? Should I mount one drywall sheet at the top and one at the bottom and patch the 8 inches in-between? Put the 8-inch section at the top? At the bottom?
