Is it ok to add a flat deck over this concrete pad( the pad is about 5 inches tall, and slightly slopes away from the house.
How would I go about adding decking over it. I'm pretty handy but just wants some tips.
Concrete stoop
Also would the same application apply for these stairs? stairs
  • Do you really want to install a new material right over top of a crumbling concrete pad? That sounds like a recipe for premature failure to me. I'd remove the concrete first. – jwh20 Jun 16 at 18:02
  • Power nailing the composite decking to the concrete would likely do in the very expensive composite decking. – FreeMan Jun 16 at 18:53
  • Based on the responses seems like it might be better for me to patch it up in the meantime, and prep for a total redo. Do the cracks Atleast look patchable with some quickrete? – Technupe Jun 17 at 0:45
  • @Technupe that's a whole new question and should be asked as such. You're not new to SE, you know the drill. :) – FreeMan Jun 17 at 13:19
You can install composite decking on top of concrete but not directly. You would need to build a frame on top of the concrete similar to a normal deck. The framing could be smaller than normal, 2" x 2" and it would be secured directly to the concrete. The distancing of the "joists" would be the same as what the decking calls for. The reason for the frame is that the composite decking still need to be aired out. Your stairs would require the same type of framing. Stairs can be tricky so you'd want to check with local coded.
The problem you have with this procedure is that your concrete is all busted up and securing your frame to it correctly will be all but impossible unless you repaired it, which would be crazy.
You could build an entirely new deck over the concrete with a larger frame not supported by the concrete. Your best choice would be to remove the concrete and start fresh.
| improve this answer | |
    Might be able to do with furring strips but it looks pretty far gone. – Ed Beal Jun 16 at 19:04
