I was replacing some toggle type light switches to rocker type and ran into something I thought was unusual. There were 3 switches boxes (2 boxes had 1 switch, and the other had 2 switches) I was replacing where in all scenarios, all of the ground wires indeed came through and into the box, but were just bundled together and not used. There was no individual pigtail coming off the bundled crimp with a ground to attach to the switches. One of the single pole switch boxes had a single ground (no bundle) that came through into the box and was tucked to the back of the box. That was the most confusing because how simple was it just to connect to the ground screw on the light switch. However the 2 other boxes had a bundle come through and just pushed to the back. The boxes are plastic and not metal so not a natural ground; the house was built in '88 so looked at that too.
Should those bundled ground wires in the back have an individual copper pigtail coming off to connect to each switch? Why would the original installer not use the ground wires, and do I need to get this fixed by an electrician or myself to run the ground bundle all the way to the new switch ground screws?
