We recently bought this place and are in the middle of updating the bathroom. Bought all new tub/shower fixtures as well as a valve. Handyman installed and flushed/tested/etc. this new valve, and I’ve since installed the new spout, faucet, shower head. Things work okay, EXCEPT when the tub is on, the shower comes on. Not just a trickle!
I’ve searched and searched to find a similar problem with answers in the forum, and what I’ve found is related to pex vs copper and shower height. Everything was copper before and still is. Also, we didn’t change the shower height. I did purchase a gooseneck shower arm to add a little bit of height/length, but it makes no difference. Not knowing much about water pressure, my gut is telling me it’s something to do with that and the new valve. It’s a pressure balancing valve that cost a good $90 and says it’s 20psi (seems low?). It fits the new faucet specifically. The old valve was a delta, and I don’t know if the previous owner had the same problem. We do live in the foothills and have high water pressure naturally. Also, although we have a VERY large and nearly new water heater, we seem to run out of hot water very quickly in the tub. Related?
I have the drywall behind the fixtures open but don’t know where to go with it as of now. Any ideas?
Thanks for reading.
valve from below Valve from side
is this turned the right way?
very limited view
sayd up
    Valve installed upside down? What sort of diverter is there for switching between tub and shower?
    – Kris
    Jun 12, 2020 at 17:18
    Thanks for taking our tour - not everyone with a problem does that. It's not clear what type of diverter (tub to shower) you've installed. Sounds like an in-faucet pressure type but don't know. We can't diagnose what we can't see. Pictures of the diverter and behind the wall would help a lot.
    – HoneyDo
  • How about a photo of the front and inside the wall? Jun 12, 2020 at 17:28
    What happens if you remove the spout and turn on the tub on?
    – JACK
    Jun 12, 2020 at 18:19
  • I was thinking some Teflon tape in the diverter or an improper install like Kris and jack are asking about.
    Jun 12, 2020 at 18:47
FIXED! The problem was these little buggers inside the shark bites. Don’t know why the handy man use shark bite instead of soldering, but those little plastic bits were restricting the flow enough to shoot everything right up to the shower. Removed them, replaced everything, now the tub works as it should. Holy smokes!
  • Anyone know what those are? It's been a while since I used Sharkbite products.
    Jun 25, 2020 at 20:43
  • @isherwood I'm not certain of the name, but I'm willing to bet that they're the sleeves designed to allow the Sharkbite to crimp into PEX or other plastic tubing without deforming it. Since OP is on copper, they're not needed.
    Jun 26, 2020 at 13:28
  • Great job finding the solution & thanks so much for posting it! Please be sure to give yourself a check mark click so everyone knows that this was solved!
  • Thank you to all who contributed! WHAT a relief to have this solved without having to tear everything out. @FreeMan, you're correct that they're for PEX, as my research taught me. Otherwise, I never would have thought to try removing them.
    – Katidid
    Jun 26, 2020 at 21:11
Most valves (all I have seen) meant for tub/shower send everything to the tub by default. The tub has a shutoff, and when you shut tub the water pressure releases out the shower.
So with the limited information that I have right now I will take a guess at your problem. You are getting hot and cold sent to valve. And you have line from valve to tub. I am guessing the line from valve to tub is too small. If you have a valve/system that allows you to change water pressure then let the water run on a very low setting, and everything should go out the tub.
If you do not have a valve system that allows you to change water pressure, then:
  1. You should be able to see the first few seconds go out the tub only.
  2. You need to restrict your water pressure to your whole house (close your main 80%ish) and then test.
There is a chance that the valve can't spit out water to tub fast enough (highly doubtful but there is a chance). This basically you starting over. So before doing that can you give me the size copper of cold in and hot in and then the size to tub and size to shower?
(also you could be running out of hot water quickly because you have a ton of water period running to this tub/shower)
12
  • Even with a 40-50 gal (normal size) water heater, one tub draining all the hot water in one session does not seem normal. Jun 12, 2020 at 17:30
  • @Programmer66 - I worked on a house in France that had a huge rainfall head over the tub. They had 3/4 both hot and cold feeding and 1" to head and tub. Hot water was gone in 15-20 minutes. I stayed at the house and it was the only shower - we had to turn off water while we were soaping so others had hot water.
    – DMoore
    Jun 12, 2020 at 17:34
  • Yes- but OP is implying one tub session, not a high demand period with multiple usage. Jun 12, 2020 at 17:47
  • I will post photos! In the mean time, yes I could have given more details. The diverter is on the spout, and the issue was present before the spout was installed. Here is a link to the valve: wayfair.com/home-improvement/pdx/…. I wouldn’t be surprised at all if it was installed upside down. This handy man turned out to be quite the...dingbat.
    – Katidid
    Jun 13, 2020 at 21:54
  • Also, we are in a condo with shared water (heater in unit, however). I don’t believe I can adjust the pressure. We get one bath’s worth of hot water. The next person I out of luck. We previously lived in an apartment and never had this issue.
    – Katidid
    Jun 13, 2020 at 22:01
There are basically two arrangements for diverting water from flowing out of the tub spout and up the shower pipe.
We call one a "spout diverter" arrangement. With this arrangement, the pipe leading to the tub spout from the mixing valve(s) has a tee in the line and is always open to both the tub spout and the shower. The tub spout is equipped with an integrated diverter valve to block flow out of the spout when desired. The water flowing from the mixing valve(s) then has nowhere to go except up the shower pipe and out of the shower head. NOTE: the tub spout diverter valves are generally not designed to be a "tight shot-off", in other words there will always be some water flowing out of the tub spout. ALSO: any other restriction at the end of the tub spout will cause the same diversion of water up the shower pipe and out of the shower head.
The other arrangement , we call "mixing valve diverter". This is where the mixing valve arrangement is equipped with an integrated valve for diverting water to either the tub or shower. The tub spout pipe and the shower riser pipe are not connected at all. The mixer valve arrangement has a seperate port for each, and has a diverter valve mechanism for sending water one way or the other depending on diverter valve position. NOTE: some mixing valve diverters will send water both ways if they are not fully set to one or the other position (or if they are malfunctioning). ALSO: there are many, many (many, many, many) styles and types and each brand and model looks and operates differently.
