I’m a new home owner. I noticed that insulation on my suction pipe was cracking. I wasn’t sure what insulation to use rubber or foam. I decided to use rubber, was I wrong?
  • James if you find an answer helpful please accept it so others that have a similar problem can find the answer. This is how the site works , thanks are through upvotes and accepted answers. – Ed Beal Jun 12 at 14:41
  • Thanks for your help! – James Jun 12 at 21:37
I have always used rubber insulation when I can find it. It's a much better insulation and lasts much longer. Foam seems more readily available, maybe because it's cheaper.
| improve this answer | |
  • Maybe I'm being a bit dense here, but what the heck is a "suction pipe"? – George Anderson Jun 11 at 23:53
    @GeorgeAnderson In an AC unit he larger line typically carries a cool gas and is insulated. This is commonly referred to as the suction line, but it is also called the return line or vapor line. – JACK Jun 11 at 23:59
  • Thanks very much, JACK! I learn so much here. It's also fascinating to learn of the different terms throughout the world describing the same thing. 2 examples: in the UK an outlet is called a socket. A grounding conductor is called an Earth wire. Many more examples but don't want to waste ppls. time here. – George Anderson Jun 12 at 0:07
  • @GeorgeAnderson You're not wasting anyone's time. We're all learning and enjoying new friends... Stay safe out there. – JACK Jun 12 at 0:33
  • @george Anderson , the grounded vs grounding can get even more confusing , then some call PE potential earth. But the suction pipe is the common name for the low pressure return in a compressed gas Refridgeration system (most common type with an outside compressor). As far as the insulation neoprene foam rubber is what most systems are built with it lasts longer and actually seals were foam normally used on water pipes can become water saturated more easily.+ – Ed Beal Jun 12 at 14:36
