I want to hang a swing in my yard and none of the trees have a suitable branch. I want to run a doubled up PT 2x8 between 2 trees spanning just shy of 10 feet. Will this be strong enough? Should I upsize to 2x10? Or is there another option? Thanks
  • It would be helpful to see a few pictures of the trees.
    – JACK
    Jun 11, 2020 at 20:59
  • Indeed - I think the big factor here will be how sturdy the trees themselves are. If they flex themselves in wind, etc, the load on the beam will be much greater. This older post may be relevant here: diy.stackexchange.com/questions/8112/…
    – Khrrck
    Jun 11, 2020 at 21:07
  • If it is kids at 100 or less you won't bow with doubles 2x10s. That doesn't mean they will be sturdy and not shake or have some other issue. Also most swings are held by hooks. I wouldn't put a swing hook into a 2x.
    – DMoore
    Jun 11, 2020 at 21:14
  • it will be attached to 2 tall sturdy trees.
    – Adam
    Jun 12, 2020 at 0:07
