I'm installing a range hood vent through a double brick wall, so I need to rent a core drill and 6" core bit. Would it be possible/advisable to use the same bit to cut through the plaster and lath (NOT drywall) on the interior wall? I would do it handheld (vs mounted as with the exterior wall) and go really slow.
  • What type of lath? A core drill is basically a grinding tool. It's virtually impossible to grind through wood with it, and metal wouldn't be much easier.
    Jun 11, 2020 at 12:51
No, it will bounce and chatter as the wood laths move.
So I would look at stitch drilling around the circle by hand with a small drill and trimming up after. Lath with plaster is difficult to work at the best of times.
  • I've made plenty of cuts through plaster & lath with a jigsaw to install boxes for switches and outlets. After picking up an oscillating saw, that made the cuts much easier. For a round hole, I'd suggest sticking with the jig saw. It shouldn't need to be a super pretty hole - the range hood will cover any rough edges. Of course, that requires having space between the lathe and the brick for the jig saw blade to move in.
    Jun 11, 2020 at 14:48
