20
When using a circular saw to cut through panels or dimensional lumber or whatever, the DIY folk on YouTube always set the cut depth to “a hair beyond what you’re cutting”. I’ve been blindly doing the same, but realized the other day I have no idea why.
Sure, obviously you need to make sure you cut through the whole thing you’re cutting. But short of protecting your workbench, why not just sink the blade as deep as possible as a default and only lift it up when there is an actual underlying surface.
Odd question perhaps, just wondering!
11
    I always assumed that the angle between the incoming saw blades and the surface would be the reason. The further out your saw goes, the more perpendicular the incidence angle between the blade and the outside surface. The less out it goes, the angle becomes closer to tangential.
    – Jeffrey
    Jun 10, 2020 at 13:13
  • Mainly, it produces a cleaner cut.
    – Hot Licks
    Jun 10, 2020 at 17:29
  • I wonder if its to expose each cutting tip for the shortest time possible to limit the chance of them flying off ?
    – Criggie
    Jun 10, 2020 at 23:45
    @Criggie - The tips are exposed to centrifugal force for the entire 360 degrees of their rotation.
    – Hot Licks
    Jun 11, 2020 at 1:25
    @RobdeJonge That is the case on some places (including other parts of SE). But on DIY a reasonable question asked in a reasonable way will be answered. We are all n00b once! Jun 11, 2020 at 14:17
4 Answers 4
32
Skil gives two reasons for it.
From the operating manual for a Skil brand circular saw:
"to minimise splintering"
and in the "kickback" warning section:
"to reduce the chance of kickback"
    There's also limiting how much blade is out to "what is needed for this cut" in the unfortunate instance that you manage to screw up and cut yourself...
    Jun 10, 2020 at 12:25
  • The curious might also consider searching videos of saw kickback, to see how quickly it can become dangerous. It's not a situation where a human has nearly enough time to react, and is a good visual demonstration of why the chance of it happening should be minimized.
    – brenzo
    Jun 10, 2020 at 17:23
    As an example of what kickback can do: In 8th grade shop class, there was a kickback during the period before mine. A 2x4 was thrown off the table saw, over 6 rows of (fortunately unoccupied) student desks (30+ feet), and made a deep, 2x4 dent in the chalkboard. Had any students been there and one took that unfortunate moment to stand up, his head would have saved the chalkboard, but...
    Jun 10, 2020 at 19:12
  • One reason that is sometimes given for doing the opposite (settings the blade with a greater depth than recommended here) is that it reduces the total number of teeth contacting the workpiece at any time during the cut. By exposing more of the blade, the teeth are (as the theory goes anyway) better cooled by the surrounding air. The claim is that this makes for a cleaner cut and is less likely to burn the work piece. (I've heard this argument made for table saws, but it seems like it would apply here too).
    – Z4-tier
    Jun 11, 2020 at 17:22
  • It's amazing how many things can be answered with Read The Fine Manual. I was talking with a guy who had trouble figuring out how to cut crown molding on their new miter saw. I recently purchased the same saw and let them know that the manual has instructions for crown molding.
    – MonkeyZeus
    Jun 12, 2020 at 15:10
13
I think the conventional wisdom is about making good habits.
I can't prove this, but intuition tells me that a saw cut that binds/jumps is worse with lots of blade out, versus "the right amount of blade".
Also, there's the risk of forgetting how close things are to the underside of what you're cutting. (You might have only a half inch under your 2x4, which could result in you cutting some gravel or flinging a loose chunk of something.) You might be relying on your sawhorse to take a tiny kerf worth of damage, but end up hacking the horse in half.
If, and I hope this doesn't happen, you were to cut a 2x4 across the toe of your boot with a full blade, it would be much more disastrous than a blade that's only projecting 1/4".
At the end of the day, do what's right for you. If you can build effortless systems around being safe with a bunch of blade, then go for it. For what it's worth, though, my coworkers who reset blade depth accordingly are generally better at their jobs. (Not trying to draw a causal link; just noting a correlation.)
  • Thanks for responding. I thought perhaps it had something to do with reducing blade wear. What you describe makes perfect sense! I'll click the tick box tomorrow, see if somebody else might have further additions to make! Jun 10, 2020 at 3:44
  • Last para, plus 1.
    – Solar Mike
    Jun 10, 2020 at 4:32
This is more of a preference of the user determined by experience in my opinion. I formerly worked building houses so I've probably made hundreds of thousands (I wasn't counting) of saw cuts.
Any saw manufacturer is going to tell you to set the blade to the depth of the material to keep people from cutting their fingers and toes off.
Advice to hobbyists:
Set the blade to depth. Don't put your fingers close to the blade. Using two hands is probably advisable especially if you are not familiar with the tool. Hold onto the saw tightly and do not let go if it kicks back. Let go of the trigger but don't let go of the handle. You really don't want a saw jumping out of the cut and dancing around by your feet. Also, use a square and mark a line. The skill saw wants to go straight. If you try to twist it in the cut that's when the blade will grab the sides of the cut and try to throw the saw backward. Make a line to follow even if you don't have an exact measurement. Following a line is also good practice.
Advice to professionals:
If you're cutting on top of a stack of sheets or something you don't want to cut deeply into you should set your blade to depth unless you want to put a piece of wood underneath it to keep the blade off of the floor or ground or wherever you're cutting on top of.
The best way to cut sheets in my opinion is to use a cutting guide such as the factory edge of the plywood/osb. Nail or screw the guide on either end 1 1/2 inches away from where you want to cut and hold the edge of the table against that edge and push it down the straight edge. You need to set the depth of your saw to pull this off. If you don't want to score the sheet underneath you can adjust it to just shy of touching the sheet underneath. Using this technique you can cut straighter than you could with a table saw and not necessarily parallel. It also saves you from having to bother chalking the line and following the chalk line, so when you get fast enough with it, the time to cut is comparable to chalking a line. If you don't understand these instructions this isn't for you.
For cutting dimensional lumber, the pros generally don't set the depth unless it's nailed down or something. You can actually achieve straighter cuts by holding the front of the table on top of the board, line up you cut and plunge down onto it as demonstrated here. Also, going full depth it's easier to cut straight as the saw blade itself is acting as your guide. If you're super concerned about kick back you probably haven't been using a saw long enough and should master the basics before attempting this.
This video has some tricks for experienced users. He likes a worm drive saw. I prefer the sidewinder type. Also, user preference but worm drive saws tend to be easier to use in some ways because the motor is mounted front to back so it's not fighting you from keeping the saw straight. With a sidewinder type you have to constantly adjust to keep the saw straight. The downside of the worm drive saws are that they are heavier and more expensive so as a novice you probably won't be using one anyway.
Advice to everyone
Never put your fingers under the board close to the blade no matter what depth it is set to. It's not like a knife where you can stop cutting yourself. They will be there and then not and they don't grow back. There's nothing wrong with a bit of caution especially with power tools.
This is about the angle of saw tooth compared to the angle of the wood. Intuitively if the saw blade is deeper (more blade sticking out) the tooth is more parallel to the surface as it exiting the wood increasing the chance of blow out.
Having the blade further away so it is barely coming out of the wood as it is cutting means it is more perpendicular when exiting the bottom face, in effect making a smaller cut.
This is partially the same reason saw blades with more teeth make cleaner cuts. More small cuts are better than fewer large cuts.
At the end of the day a saw blade is just a disk of many chisels. If you were trying to reduce blow out when cutting through a piece of wood with a blunt chisel, how would you hold it? Now think of what the saw blade is doing.
Making smaller cuts also reduces kick-back!
    Suggest you review geometry terms, as you appear to have this exactly backwards. Feel free to edit & correct.
    Jun 11, 2020 at 13:38
  • Other than @Ecnerwal's comment about switching the geometry, you are correct. Less blade protrusion below the cut will generally yield a cleaner cut. Make that edit and you'll get my vote!
    Jun 11, 2020 at 14:41
