I have a nice pair of over-ear headphones but the ear pads cracked apart. Any idea on how to fix this is very welcome. Photos: enter image description here
    Unfortunately, "small appliance repair" is off-topic here. And, you should probably take our tour so you'll know you'll know the details of contributing here. – Daniel Griscom Jun 8 at 12:38
  • I’m voting to close this question because it's a small gadget repair question... – ThreePhaseEel Jun 9 at 3:14
Clean both surfaces and use either Superglue or a glue gun to stick those two surfaces together.
| improve this answer | |
Buy a replacement set of pads, remove the damaged pads, clean the surface, apply the new pads (typically an adhesive mounting.)
