The dryer lint trap quit fitting. We cant put it back in as if it is too big. Have looked and doesn't appear to be anything blocking it and lint trap is cleaned after each use
    So what's the question? How about a few pictures so we can see what you see. – JACK Jun 6 at 20:23
  • Hello, and welcome to Home Improvement. Unfortunately, we'll need more info before we have any chance of helping you. Please take our tour so you'll know how best to participate here. – Daniel Griscom Jun 6 at 23:57
Most lint filters on dryers have some type of gasket to reduce air bypassing the screen. There may be a gasket on the removable filter itself or there may be one incorporated into the filter receptacle/slot. I have seen these gaskets come unglued and bent/crumple into the slot that the filter goes into. Check for obstructions.
| improve this answer | |
  • There is no gasket and doesn’t appear to be an obstruction. The lint trap is a solid plastic – Gary Jun 6 at 23:54
