I want to build a 15ft long retaining wall which is located at the bottom of a slope, surrounded with springs, against the fence. In searching for materials I have no idea which fabric I should choose among so many types, and what gravel is for.enter image description here
  • "springs" as in places where water comes out of the ground? Please add a photograph of the area.
    – Niall C.
    Jun 6, 2020 at 2:37
  • Hi, the area of springs were filled with dirt and bushes are covered on. Water comes out from the bottom and flows away under the fence. I can see the fillings moved down, that is why I want to build a wall to stop.
    – yahu
    Jun 6, 2020 at 3:17
  • How tall a Is this wall 15’ wall and what type of construction? The gravel helps with drainage the fabric helps to contain the dirt so it doesn’t migrate as quickly into the gravel.
    Jun 6, 2020 at 15:28
