Stuck Patio Sliding Door is similar but has a different locking mechanism
I have a sliding door to my balcony which is stuck on one end. I cannot push the lever/button down that will unlock the latch.
I tried to remove the entire front face by inserting a sharp object (a small screwdriver in my case) at the pointed areas but I could not make much of a dent. I am unable to try this from the other side as there is no clearance to do so.
How do I remove the cover or unlock the door? I cannot slide anything between the frame and the door to unlatch as there is not room there.
A picture of the latch from the other side
