I used the Bathworks re-glaze kit on my bathtub. I did amazing prep but then I used too much paint.
The entire thing started to slide and then I got drips that I was unable to get rid of. Now that it is dried I'm wondering if I can gently sand out the drips with fine grit.
I have read that I could sand and then follow by using a polisher with a rubbing compound.
Has anyone done this? Tips welcome.
  • Welcome to Home Improvement! Have you read the instructions, visited the manufacturers web site and/or contacted them via phone or email? They would be the authoritative source on their product... While you're waiting on a response (from them or from us) feel free to take the tour and read through the help center so you'll know how to get the best from this site.
    Jun 2, 2020 at 18:48
  • I have polished out a drip or two using very fine paper wet and buffed out finishes but a slip or slide I’d a big area and may be tough but it’s worth a try I use 1200 grit to start but a big area or larger may require 600 or 400 to start then go finer and finish buff.
    Jun 3, 2020 at 18:51
  • Yes, use (wet) sandpaper with a rigid sanding block to knock down the proud drip, then polish out the result with compound.
    – Huesmann
    Mar 2 at 14:13
