My tenant reported that ants have been digging dirt up between the cracks between house and sidewalk.
However, this seems to be quite a lot of dirt. Could it possible be termites causing this?
9
  • IDK but that's certainly quite a lot of dirt. But I'd assume w/e kills termites would kill ants and vice versa. And I don't see what a termite would find interesting below grade and next to a stone (?) foundation, and a real brick wall (?) that's not a facade over framing... unless you live in Australia (location ?)
    – Mazura
    Commented May 28, 2020 at 12:32
    Ants, IMO. Termites don't like light, that's why they build mud tunnels. The ants are building a nest somewhere behind/under the brick. And that's probably a brick facade, with an airspace between the back of the brick and the framing/insulating material. My house is built that way.
    – SteveSh
    Commented May 28, 2020 at 13:09
    While you're deciding on a long term solution, you could start by spraying bug killer down the gaps between concrete and brick as a short-term fix.
    Commented May 28, 2020 at 13:10
    I would go with ants and get an exterminator in there right away that is a huge amount of material, I know ants will take the dead out with the debris that’s how they identified the type on houses I have had treated. I know termites do dig but I haven’t seen them bring material out like ants.
    Commented May 28, 2020 at 14:10
    2 words: boric acid.
    – dandavis
    Commented May 28, 2020 at 18:46
I agree with Steve. Ants for sure, maybe pavement ants. You can find several pesticides at DO MY OWN PEST CONTROL. I worked in pest control for 17 years. A Termiticide / Pesticide called Termidor SC will get rid of them for sure. Kinda pricey but it's a concentrate.
You'll probably pay more for a pest control company to do it. Do it yourself. One Ounce per Gallon of water mix should do it. Just follow the label instructions on the bottle.
  • Welcome to Home Improvement. Some formatting, proper capitalization and not shouting would be welcome additions to this answer! Feel free to edit your post to fix things up. Also, it appears that you're promoting a web site and/or product. It would be great to mention if you're affiliated with either - it's fine if you are, just let us know. Otherwise, this may get flagged as spam.
    Commented May 28, 2020 at 18:32
  • Woody, I have a friend that used a special “licensed only” ant killer in the Pacific Northwest. It lasted ~10 years and killed all ants in ground and on wood. Do you know the name it really worked and may not be legal any longer as that was a few years back. I had spent a lot in that area trying to kill carpenter ants and that was the only thing that worked 100% on multiple houses I remodeled and owned. My friend retired and moved and I can’t find him to ask.
    Commented Jun 2, 2020 at 13:50
