I have this couple bed that need to disassemble but have no idea how to unscrew this bolt in the pictures. I have never seen anything like this in my life.
Thanks in advance
Sign up to join this communityI have this couple bed that need to disassemble but have no idea how to unscrew this bolt in the pictures. I have never seen anything like this in my life.
Thanks in advance
A pin is used through the head to unscrew. A drill bit or Allen key as large as will fit will provide enough torque to get them out unless someone used pliers on them but I don’t see any damage.
Many had decorative handles on them that after being tightened one times too many and broke.
That's a good way to keep the kids* from taking it apart!
I've never seen one like that, either. I'd presume that something thin like a hex-key would fit through the hole on the knob on the outside to turn it while an adjustable wrench would hold the square nut on the inside.
*My then 2-year-old started removing screws from the under side of my desk. Because God's got a sense of humor, his 2 year old did the same. :)
