I have an HVAC system that has a condenser fan motor that has gone bad. The motor is no longer available. What considerations do I need to make in order to replace the motor with a different motor?
For example, if the voltage is the same, can I replace the motor with one that has similar speed? Would it just require a matching capacitor?
Additionally, can it be switched over to brushless?
