It’s a small plastic one like you would use to hang a poster or calendar. Sink drain
2It'll probably be fine once it gets into the big 2"+ drain, but if it gets stuck before then, it'll catch more stuff and create a clog. How are you at taking apart traps? (it's a skill that is good for ring wearers to have). – Harper - Reinstate Monica May 24 '20 at 15:42
"the drain"? Most bathrooms have 3 - sink, tub/shower, toilet. Which one? – manassehkatz-Moving 2 Codidact May 24 '20 at 15:45
1If it can fit down the strainer width-wise, no problem. Length-wise, like a q-tip; that's a problem. – Mazura May 25 '20 at 0:07
I can't imagine it doing any harm and it's not worth the effort to remove the trap to try and find it as it probably has already passed the trap and is in the sewer. If you like to fish, you could fasten a magnet to a piece of string and lower in into the drain and try to snag the tack. Just don't lose the magnet down there. You could also remove the trap but that can be messy and why take it apart if it's not leaking.
3A trap, which is not leaking, which is taken apart, will never again not leak :O – Fattie May 25 '20 at 1:09
1Downside of a magnet on a string is that it may drop, get stuck to something ferrous, and will not flush away. And its also possible the tack isn't ferrous anyway so the magnet may not attract it. OP says its plastic but that's probably not the sharp pin, which might be stainless steel and therefore not magnetic. – Criggie May 25 '20 at 2:29
Unless you have a sewage pump I can't see it being a problem. Maybe if your line is already clogged enough to be a problem.
