Is it possible to somehow connect this air conditioner? Would I have to simply change the outlet receptacle to the one it could connect to? Can I buy some sort of an adapter? Is it easier to return this air conditioner and get a 110V?
No, there is no magic doohickey to solve this problem. Not least because it introduces a bunch of other satellite problems.
These aren't like "Windows vs Mac" 2 incompatible flavors of the same thing 240V is actually more powerful, so an A/C unit would not be made 240V unless that was necessary to power its functionality. So a 240V A/C will probably overdraw a 15A circuit even if you used the (non-cheap) tech to convert.
The right thing is to take it back and get an appropriate A/C. How did the salesman not have this conversation with you and make sure you had 240V power available? Don't do business with them again, they stink at their job!
    Another salesman with Swiss Cheese knowledge (where'd I get that from). Definitely take it back. It's not worth the effort to jury rig it and you'll probably void the warranty. +
    – JACK
    May 23 '20 at 23:33
