Had to replace a downspout because it was stepped on. I replaced it with a downspout extension, which is longer and does a better job of letting the rain water drain away from the house.
The only issue I'm facing is if we have a heavy rain or high winds, the downspout extension comes off, thus defeats its purpose.
Is their anyway to keep this extension on when experiencing heavy rain and winds?
(can't upload a pic because its too big)
thanks
  • White sheet metal screw through the overlapped sections. Or if you want to get fancy, a pop-rivet. – SteveSh May 23 '20 at 21:32
  • If you can't figure out how to resize your photo, use words. The question is too broad otherwise. – isherwood May 23 '20 at 21:38
  • @SteveSh Type your comment up as an answer. – JACK May 23 '20 at 21:52
White sheet metal screw through the overlapped sections. Or if you want to get fancy, a pop-rivet (converted from my comment).
Note to Jack - some of the other SE sites seem to discourage 1 (or 2)-sentence answers. I have been asked on at least one occasion to convert an answer into a comment.
    Simple answers for simple problems are fine! +1 – Jimmy Fix-it May 23 '20 at 23:38
  • This site is a bit more friendly and understanding than many others. – JACK May 25 '20 at 12:28
  • If one or two sentences actually answers the OP's question, they're fine.+ – JACK 22 – JACK May 25 '20 at 12:51
