I was planning on making a 2 post swing set. Posts 6x6 inches (5.5x5.5) by 12 feet. 4 feet into ground with cement. Cross beam of 6x6 inches (5.5x5.5) by 10 feet with 2 swings. Will this be strong enough for the forces? I realize an "A"-shaped structure is stronger but I was wanting to do a 2 post swing. Thank you.
  • 4
    There is a reason you see A frame (4 post) and not 2 post swings The lateral forces are massive. you want 8’ tall possibly if your 4’ hole is at least 24” in diameter and filled with concrete it might work, if smaller it won’t be long before the posts are flopping back and forth. Not saying it can’t be done but you will have to counter the forces. A large base may work.
    May 22, 2020 at 3:02
    And how heavy will the kids be next year? And the year after..,
    – Solar Mike
    May 22, 2020 at 6:45
  • @EdBeal Wow Ed, you said that really, really well. It's a 3-dimensional answer in a comment without even a paragraph. May 22, 2020 at 14:35
  • You know what, I would weld the 5.5" channel to a horizontal section at the bottom, so it is an inverted T - with the bottom part completely buried. That will give it A-frame stability with the plain post aesthetic. May 22, 2020 at 14:43
Back in the dark ages, when playgrounds were built with concrete and asphalt surfaces, I saw 2-post swing sets built with 4-6" diameter steel posts (I was a kid then, I never measured accurately). If you want to use steel and weld it up, you're probably good.
If you want to use wood, you'll probably have too much flex. One of those posts could snap after some use (not day one) and send a kid flying. Flying off a swing at the top of the arc is great fun (even at my age), but having it be an unplanned event, with large chunks of wood following, would be considered by most to be a Very Bad Thing™.
Consider both swings going in sync - you've got all the weight pulling on both posts in the same direction at the same time. Now consider both swings going in opposite directions - each post is going to bend in the direction of the local swing, and the cross-member is going to twist. If your kids are even remotely normal, as they get older (and heavier), they will want to see how far they can get the thing to bend by swinging in unison, and how much they can make it twist by swinging in opposite directions.
Bear in mind, your kids may be small now, but they'll grow. We had a small steel swing set in our backyard that we installed when our kids were small. They continued to use it into middle school when they were in the 50-100 lb range. They continued to use it in high school when they were 100 lbs+. They had friends over and had more people on it than it was designed for. They had people swinging on it and hanging on it and climbing on the top bar all at the same time. As they hit middle school (and even earlier) they thrilled at trying to make the A-frame swing set lift up by swinging in unison. It came with screw-in anchors. We had to buy more anchors and bigger ones and put one on each of the 8 legs to keep them from tipping it up. It's just what kids do.
No amount of parental policing will ensure that the swing set will only be used according to today's design standard, and even if you manage that, there will be kids sneaking in when nobody's watching, mostly because you've gained a reputation for being the "swing set Nazi" and they want to show you!!! It's just what kids do.
After 10 or 15 or 20 years of rotting weathering and hard use by heavier and heavier kids (we took ours down just a couple of years ago after 2 of the 3 kids moved out - they would still swing on it with their college aged friends when they had them over), even pressure treated lumber will start to wear. There's really no telling when it might give way. Wood's a natural product and the average strength of a PT SPF 6x6 might be sufficient, but the particular pieces you pick up from the lumber yard may be below average (or may be well above average, who knows).
Spend the extra money and yard space for an A-frame design. You don't want the neighbor's kids going to the hospital and their parents suing you.
  • You should replace "not a (trademarked phrase)' with the trademarked VeryBadThing(tm) :-) May 22, 2020 at 15:34
    @CarlWitthoft good point. Done.
    May 22, 2020 at 15:43
I stayed at a bnb recently and they had a two post swing set, I swung on it and it didn't budge, I'm 210lbs. It was made with 6x6 wood posts. I don't know how deep the post went or how much cement they used but with enough depth and anchor weight it seems to work.
We've had one in our yard for 12 years. Ours is extra wide, large enough for 2 swings and a glider. It has held up perfectly and was rock solid until just this year, when it started to have a slight wobble. I'd refill the concrete footings, but my kids are old enough now to just remove it entirely.enter image description here
    Some extra description, like how tall are the posts, how far apart they are, how deeply they're buried in the ground, how big the holes were (thus how much concrete), what climate you're in, etc. would be really helpful. As I noted in my answer, all wood varies in strength, and maybe you managed to get a couple of above average pieces.
    Jul 7, 2023 at 23:37
