I'd like to freshen up an old barn door, to make my lockdown productive.
It looks really bad, hasn't been taken care of in a long while, and I wonder if there is anything useful I can do, or if it is just too late.
What should I be looking at to determine this?
Follow-up answers:
  • Does the door still operate or is it merely decorative?
It still operates. As a matter of fact, the main reason I want to work on this door is to keep it operating for as long as possible.
  • There is some rot at the bottom, particularly on the right. Is that sturdy enough or does it need to be repaired to keep it from falling apart in use?
The door is actually two 1" (2.5cm) board, screwed together. Even at the worst point (bottom right in the first picture) there is plenty left, and it feels very sturdy.
Altough there is some wood of similar dimension (width and thickness, but shorter) laying around, I don't remotely have the skills to replace the boards myself, and rust melted the screws and bolts.
  • Do you want to paint it and hide all the patina or do you want to put a preservative/sealer on it just to keep it from falling apart more?
I think it looks kind of nice. It's been out there for 80 something years, my goal is to keep it going a bit more :)
  • Do you want to spiff up all the hardware or leave it rusty?
I would try to make it all better.
Is is too late?
No, I don't think so
What should I consider?
    • i.e. will repairs to the mechanism be necessary? You may need to grease, repair or replace the wheels up top and/or fix up the rail it hangs from.
    • Or are you happy with it stuck open and you just want it to look nicer different?
    • Do you have the skills necessary to repair the door if "freshening" it includes replacing the rotted wood?
    • Repair could involve replacing an entire board or just cutting off the rot and patching in a new piece.
    • Do you have extra old wood laying around that would match in width, thickness and general patina? Modern dimensional lumber probably will not match, especially in thickness.
    • Any new replacement lumber will look different, even if the whole thing is painted a solid color. They just won't have the same wear. You'd have to "distress" the new wood to make it look "right". (Using old wood that's in better condition would be the preferred option, in my opinion.)
    • Do you have access to a local lumber mill (that's open) that could supply you with lumber of the required dimensions?
    • Replacing entire boards (especially the two on the right-hand side of the pic) will involve removing the roller hardware and the handle. Can you get those bolts lose or are they rusted into one solid mass?
    • You will want need to scrape or gently (very gently at first - hard to tell what kind of condition those boards are in) power wash the wood to get all the loose dirt and gunk off of it before attempting to apply an sort of coating. If you don't, a preservative won't soak in very well, and a paint coat will just fall off in the next stiff breeze. i.e. you'll keep busy for now, but you'll be busy again next spring fixing up the mess you left behind.
    • Personally, I'd go with just a preservative or sealer to allow the patina to show through. Even this will change the color of the wood some, but it will have minimal effect in comparison to a stain or paint.
    • If you've got other painted wood on the barn and you paint this to match, that would make sense. Do you have, or can you get paint to match?
    • I'd seriously consider hitting the metal work with a wire brush (drill powered, unless you're looking for a serious arm workout) to knock the heavy rust off, then paint it with a rust converter that will turn the oxidation into a protective coat. These are usually available in a variety of colors to coordinate with whatever color you choose to paint - I'd think just a simple black would look nice.
    • Converting the rust to a protective coat will definitely lengthen the life of the ironwork.
    • I'd include spiffing up the rail that it hangs from, too.
    • You could paint the iron work after applying the rust converter. Depends on taste and desired aesthetic, of course.
  • Thank you for your comprehensive answer. I have updated the question with answers to your questions. Based on your answer, I think I'll go the clean / preservative way. Replacing boards feels way out of my depth
    – Maxime
    May 21, 2020 at 12:28
  • @Maxime Your question was "what should I consider?" I answered that question with a list of things to consider. There was no need to answer them publicly, they were a list of things for you to consider. :) TBH, though, I'm glad to hear you want to leave the patina - it think it looks great!
    May 21, 2020 at 12:36
