Are junction boxes required for 24v splicing in the United States? Are small plastic enclosures sufficient or would you use standard junction boxes for 110v?
The application is a 24v lighting system operating on a trunked design. Each trunk would power ~85w of LED strips.
  • These plastic Tee connections would all be surface mounted, There should be no need for an enclosure. May 20, 2020 at 17:28
  • My concerns would be are you trying to link all the branches to one main trunk line. Normally the max is two 5 meters or 36' per feed. So you would have a 2-2-1 for your three feeds out of the transformer. May 20, 2020 at 17:48
  • Currently the system is just bare wire soldered to the LED strips and connected to the trunk with wire nuts. Though i suppose if a barrel-style plug connection is considered safe for 90w of power then that'd be an option. May 20, 2020 at 17:53
  • I am talking about 10mm Tee LED connectors, which is a much cleaner connection like these sample tee connections. Remember 32' max length can be connected together on a circuit. Your strips would look continuous. They also have the connectors with wire in case you don't want continous light at the Tee May 20, 2020 at 18:30
  • Those Tee connectors would work great for someone that has the lighting installed continuously. In my case I'm using it as shop lighting in my garage so i've got it installed as 2' segments spread evenly all throughout the 25' x 25' shop. May 20, 2020 at 18:53
No that voltage is below the safe contact limit threshold the wiring could even be exposed but not recommended.
