I have a finished sun porch that is resting on 4 - 4" X 6' round steel post.
The base of these post were buried under dirt for several years and have rusted. A couple of the post have about a 1" hole near the base plate. I tried to get this fixed professionally, but the estimates have come in around $3500 to replace the existing steel posts.
I was wondering if I could replace these using 6" X 6" x 6' pressure treated lumber. The porch is 12' x 13', glassed in with a roof and tile floor, so I am assuming that it weighs quit a lot.
Will the pressure treated lumber withstand the weight? Other PostRusted Post
Porch
Just wanted to says thanks for the advice. I was able to replace all the steel post successfully and without too much trouble. I did build 2' deep piers for each post, 8 inches in diameter. Each pier took two bags of 50lbs concrete. On these I places a 6x6 post base with bolt secured into the concrete.I use a jack to slightly raise the porch floor so I could remove the existing post and install the new ones. Taking my time I did each post one at a time.
enter image description here enter image description here enter image description here enter image description here enter image description here
Final result:
| improve this answer | |
    Excellent work and the proper way to do it. – Alaska Man Jun 8 at 17:40
  • Well done, indeed! Thanks for coming back with an update on what you did. Just make sure you click the check-mark next to your answer so the system won't bump it to the top every few months. You also get a couple of bonus internet points, redeemable for unicorns and rainbows! :) – FreeMan Jun 8 at 17:49
Yes, they will bear the weight. Your porch is a typical use case for such posts, and the span between is also typical. Just be sure they're rated for below-grade use.
  • Does below grade use imply that I will be burying them or should I place them on a concrete pier above the ground? Thanks for your help. – Ashby Sharpless May 22 at 18:47
  • That's really up to you. I assumed they were in the ground (at least somewhat) now. – isherwood May 22 at 18:55
