Im not sure how to connect these ground wires. Theres a ground wire connected to green screw on electrical box, and theres another green screw on the light fixture bracket. Thanks
[3]: https://i.stack.imgur.com/sGDvl.jpgenter image description hereenter image description hereenter image description here
That's a strange ground clip on the electrical box. The box doesn't appear to be metal and that clip will interfere with your fixture bracket. I would remove that clip from the box and pigtail those two grounds to a 6" piece of bare copper wire. Install your bracket. Wrap your extended ground wire around the green screw on the bracket. Connect the end of the extended ground wire to the ground wire from the fixture with a small wire nut.
    I agree that the ground screw looks like it would foul the fixture bracket, however, it does look like its a (heavily) painted metal box, because that flat piece that the ground screw is attached to looks way to thin for it to be a plastic box. I do agree with your recommendation to pig tail the grounds. It looks like the ground wire goes near the ground screw in the box, then continues on. I'd investigate further to see where it goes. I'd also carefully/gently scrape some of the paint off the wires just to make them easier to identify. (Don't damage the insulation!)\
    May 19, 2020 at 13:48
  • @FreeMan That had me puzzled too but the mounting screw on the top and the widening on the left just looked like nonmetal. The ground wires looked like two shepard hooks (poorly) , one almost out. At least two cables so two grounds. :-)
    – JACK
    May 19, 2020 at 14:11
  • Ah, yes, the 2 rounded parts going from the opening toward the back do look like the fixture-screw mounts on a plastic box and that thin piece with the ground screw looks like an add-on piece of metal... Darn painters!
    May 19, 2020 at 14:17
    I remember seeing those “clips” or adapter plates on round boxes to allow different sizes of shell covers but I haven’t seen them since the concentric ring plate adapters became popular. Those adapters work on both metal and plastic that looks like a brown fiber box to me. Look at the ring adapter above and realize that will fit with any box the clip or plate won’t center the shell as well probably why we don’t see them any more.
    May 19, 2020 at 15:03
  • I wonder if that tab on the box is there to bond some type of integrated metal spreader bar or some type of metallic support of an old work box? Rather than immediately abandoning that connection I would first try to flatten the surface plane by unwrapping the existing ground so the wire doesn't overlap where it exceeds 360º. The green screw on the adapter and the bare from the light assembly need to be pigtailed to the ground wires in the box. May 19, 2020 at 16:32
