Today I drained my central heating/hot water system. This is a standard vented, pumped S plan with two electric valves and an indirect hot water cylinder, and I'm in UK.
I was lucky enough to have a drain valve underneath ground floor, relatively accessible, see pics:
So I opened it and was able to drain: good! However, upon refilling the system, I found out that that valve will rotate endlessly, and won't guarantee proper isolation: it's stripped.
I was thinking to add an isolating (aka service) valve past the old one, i.e., along the pipe in the bottom part of the images.
Something like this: enter image description here
Do you think that will work? Or is there a risk that the old valve will leak when the new one is shut? Do you foresee any other possible problem?
Any feedback welcome!
Thanks!
    For those of us not in the UK, would you mind editing your post to describe what a "CH/HW" is. Also, did your work involve turning the valve in question, or was it left alone?
    Commented May 18, 2020 at 17:26
  • Thank you! I don't have an answer for you, but at least now I know what you're talking about.
    Commented May 18, 2020 at 17:40
Adding one of those isolators is a good plan.
I used to put one inline with every tap as they are cheap and make subsequent maintenance easy - less draining of the whole system.
