I was thinking about having a carpenter mount a window air conditioner in a room. But, the problem I always have with window air conditioners units is that the humidity is too high where I live and the unit fills up with water and overflows leaking water onto the interior dry wall.
What’s the best way to solve this problem? Is there a brand of window mount AC that is suitable to be permanently mounted in a humid climate and won’t start to destroy the walls with water damage after a week of use.
You can’t really tip the air condition over if it’s mounted in a wooden frame by a carpenter can you?
