So I live in an rental with a forced air furnace. The thermostat that controls it is an old honey well that uses ancient analog components. It works well during the winter for heating, but unfortunately I realized with summer coming on it has no option for a fan mode. Pulling the thermostat off the wall I found that the wiring only has the red live wire and white heat wire running to the furnace.
After googling around I figured out that basically the thermostat is a fairly dumb component that just connects the red 24v to different input wires to active different heating/cooling mechanisms. Following this logic then I figured I could go to the furnace and rewire the connections to furnace board such that the white wire input instead connected to the fan terminal. I did all this and then replaced the thermostat to a rocker switch so I could easily flip it on and off. So far the fan is humming along nicely and things are cooling off.
My question is this, since I cannot solve the problem correctly by running more lines and getting a updated thermostat (I figure my landlord wouldn't like me doing impromptu wiring) is this a safe long term solution?
