I’m daisy chaining 4 LEDs that aren’t grounded and was wondering what to do with the last ground wire. For the first 3 LEDs, I connected the grounds with a wire nut (see picture). What should I do with the ground wire for the last LED where there will only have a single 14/2 wire coming in? Cap it with a wire nut?
If there are no grounds on the fixtures, just leave the ground wire unconnected and in the enclosure. Personally, I would cap it with a small wire nut to prevent it from working its way into the connectors. The ground wire is connected at the other end, right?
Yes, the source of the first LED is grounded to a jonction box and eventually to the electric panel. That’s what I thought to put a wire nut on the last ground wire. – Simon Arsenault May 17 '20 at 21:27
