Breaker tips the second I turn it on. Exactly 5 outlets aren't working. None of the outlets are CFCI, all look like the one in the picture, but others outlets aren't next to light switches and have panels over them. All lights and everything else is working. No apparent damage to the outlets. These outlets used to work fine with no issues. The only recent change was I connected a toaster oven to this outlet, but the problem started a couple days later. I took the plate off of the outlet and it looks fine. The light switches next to it work fine. The other 4 outlets aren't damaged and used to work fine.
What I've tried:
- Remove everything from the outlets
- Replace the breaker
EDIT:
Is this the issue? This wire looks burned here on this outlet.
EDIT2:
It was the issue. I removed the outlet and the breaker stays on now and other outlets work.
