I have recently installed a new washing machine. In the new machine, as well as for the old one, there is a leak as indicated in the following picture:
https://i.sstatic.net/Z057M.jpg
What could cause this? I have screwed the clamp tightly by hand - should I be using a tool to do this?
Note: this is on the cold side, and the hoses are new, but the faucets old.
    Looks like the rubber / fibre washer is missing
    – SiHa
    Commented May 13, 2020 at 9:01
    Either a missing seal washer as @SiHa says, or a damaged sealing surface on the faucet (a picture of the business end of the faucet with the hose removed might be helpful.)
    Commented May 13, 2020 at 11:41
  • hotglue the seat if you can't get a washer.
    – dandavis
    Commented May 13, 2020 at 16:12
Make sure there is a washer in there. Compare it to the hot water side for the washer.
These fittings always say "hand tighten ". I have seen very few that tighten sufficiently by hand, especially when dealing with head pressure. Take your pliers or Channelocks and give the nut an eighth of a turn further than your "hand tight".
  • Hand tighten+ solved the problem - thanks!
    – Leon
    Commented May 17, 2020 at 23:19
There should be a rubber "rubber" washer in the plastic union that screws onto the tap.
(the washer is usually some sort of flexible plastic, not actual rubber)
It's called a hose union washer and should be available at most places that sell hardware or plumbing supplies.
I have in the past used slices of actual rubber hose to replace lost washers.
If there is a piece of fibre in the joint that could cause a slow leak. so when you undo the union to check for the washer, if you do find a washer make sure that it and the surface below it are clean and undamaged, and that the mating face of the tap is also clean.
  • A little Teflon tape on the threads wont hurt either
    – Scott
    Commented May 14, 2020 at 0:52
