I have a room that has some wood paneling in it that we are going to have to replace, as it is old and has a missing section that is hidden by a cabinet we want to remove. I am considering doing either normal drywall or doing floor-to-ceiling board and batten walls for some extra style. For board and batten, I seemingly have two choices for the bottom layer: drywall, or paneling/plywood. I don't want MDF paneling, and HDF or wood paneling runs pretty expensive, as does plywood that's attractive enough. Therefore, even if I do choose to do board and batten I would like to stick with drywall.
My question would be if I do drywall WITH board and batten, would it still be necessary to tape the seams if I have 1 x 4 boards over them? Is still necessary for structural integrity?
  • ...board and batten is boards, not drywall or plywood, with battens (narrow boards) over the joints between boards. You appear to be doing something I might call drywall and battens, which is going to look entirely different than the same thing done with actual boards...
    May 13, 2020 at 1:07
  • The idea would be something like what is shown here. I saw this same thing done in an Airbnb house I stayed in once, but I could not tell if the drywall had been pre-finished: thehappyhousie.porch.com/diy-floor-to-ceiling-board-batten May 13, 2020 at 4:25
It is not necessary. Generally speaking, taping is done entirely for aesthetic reasons (where a firewall isn't needed).
  • Plus for adding the fire wall that’s what I was thinking also.
    May 12, 2020 at 21:03
