I just bought a house that has one of these where the TV would go. I do not want to change things or do any re-wiring.
It only has two ports. I have 4 devices:
  • A roku
  • TV
  • Soundbar
  • Samsung SmartThings hub
My thought was to use a normal surge protecting power strip and plug it into this wall outlet. But, since this wall outlet is surge suppressing, I am not sure if I should. Is it dangerous to do so?
https://www.homedepot.com/p/1-Gang-Recessed-TV-Media-Box-Kit-with-Surge-Suppressing-Outlet-and-Low-Voltage-Inserts-White-TV1WTVSSW/304271154
The "don't put a surge protector on a surge protector" rule is not about the surge protection, it is about overloading circuits and tripping over wires - which really doesn't apply here. I would treat the installed receptacles as "ordinary" and use a surge protector (of known quality) to add more receptacles.
