I’m having my backyard dug up and regraded next week in order to install sod and so I figured I’d try and take a stab at designing and maybe installing an irrigation system as the area is not very large. I know there’s a lot here, but any guidance would be greatly appreciated. Here’s what I’ve gathered so far:
I’m in the Massachusetts so I will need to take this into account in terms of winterizing the system. There is generally good drainage and it is mostly sandy although with some areas of clay. We will also have a layer of top soil put in with the sod.
The supply line is 1 1/4” galvanized.
I’m not sure on the water meter size, but I think it’s 5/8” per the below image. I’d call my local water and sewer department, but they have been closed since March due to COVID.
water meter
My flow rate is a bit difficult to measure because the spigot is really close to the ground. I tried through a 50 foot 5/8” hose into a 6 gallon container and that took almost exactly 1 minute. Measuring with a 1 gallon bottle direct I got about 7-8 GPM, but it’s difficult to measure with that small of a container.
My pressure seems to come in fairly consistently at about 84 PSI, but my vacuum breaker is slightly leaking. Measuring from another spigot I was getting 90-96 PSI (although it’s much closer to the supply line, but they both stem off from the same line which is a 1/2” pipe, that comes directly out of the water meter, into a 3/8” pipe). I know this is high - I’ll come back to this in my questions at the end.
water spigot water spigot 2
I believe modern frost free spigots like this should also have backflow prevention so I don’t think I need to install anything additional for that (provided I fix the vacuum breaker or washer or whatever it ends up being)?
I used the Orbitz online design tool to build a layout of my property. I’m not particularly tied to using Orbitz products and am certainly open to suggestions, but I appreciate the ease of use of this tool and them telling me pretty much exactly what to buy.
Here is the layout I’m working with
layout
The red triangle is where the water connection is. There is also an outdoor plug right there. The deeper green area on the right side is hedge where there are mostly hydrangeas. The property will be graded such that the top of the picture will be the lowest point. The property is surrounded by a 5’ fence, trees, the house and a garage so wind is not a significant concern.
For this plan the Orbitz service only allowed me to enter a max supply line size of 1” and PSI of 75. I conservatively went with 7 GPM for flow rate.
Here is the resulting suggestion (I didn’t add a manifold - see questions below)
plan shopping cart
Questions:
  • Do I need a pressure regulator? Is there something I can install in-line without requiring plumbing work and also that does not affect my GPM?
  • Do I need auto-drain valves? I’m guessing these would be installed where the two sprinklers at the top of the plan image are? Maybe it’s just easier to blow out the system with an air compressor before each winter?
  • How deep should I be burying the system? Is there a trick to making sure it gradually slopes down?
  • Is there an easy way to tap into the system to also water a couple of potted plants?
  • Do I need a manifold and do I need the suggested controller? If so it seems like this project gets a bit more complex. I’ve done plenty of electrical work inside my house, but nothing outdoors beyond nest doorbells). I’m guessing I can ditch the controller and go with a more basic water timer like the Netro Pixie. Or maybe it’s not so bad considering I have an easily accessible outdoor outlet? What would I use to connect the spigot to the manifold? Alternatively are there any plug-in smart manifolds with more than one zone that just attach directly to the spigot?
  • Do I need to install anything additional for backflow prevention?
  • Anything else I should know or consider?
The pre-work you've done lays the foundation for a great system. Good job.
Use a pressure regulator
The length of throw, the precipitation rate, and the GPM flow requirement quoted for a particular sprinkler all are based on an assumed pressure. That's commonly around 45 PSI, but check data or information sheets from the manufacturer to be sure. If you can't find published data then move up to a higher tier of sprinklers or change manufacturers. When a sprinkler is run over its nominal pressure it'll throw too far, make more noise, atomize the water smaller (and thus be more susceptible to wind drift), demand too many GPM..
Winterization (Drain or not?)
There are two schools of thought for winterization: design the system to be drained or plan to blow the water out with compressed air. Draining could be manual or automatic. Either way draining takes up-front planning and somewhat careful construction. Automatic draining is maintenance free (unless/until the drain plugs clog). It does consume more water because all the pipes are filled and drained with every operating cycle, and it's more noisy (popping and hissing) when the sprinklers first come on and expel the air from the pipes. Manual draining and blow-out both avoid those drawbacks but require attention every fall. Blow-out can require a sizeable compressor -- a pancake style won't do. If you choose blow-out or manual draining then you don't need the automatic drain plugs etc.
Burial depth and slope
When rigid riser pipes were the norm burial depth had to be kept within about 6-10 inches. With the connection to each sprinkler made by swing pipe, often called by the Toro trademark "funny pipe," burial depth is largely a matter of preference or convenience.
Slope really only matters in a manual-drain system. It matters little if winterization will be done with compressed air. In an automatic-drain system you can figure out where the low points ended up and add automatic drain plugs at those places. Remember that those plugs eventually fail, though, so document their locations -- but consider controlling the slope of the pipes so that the auto drain plugs can be put in locations that you prefer. Maybe even put them in a sprinkler valve box so they're easy to find and access for inspection or replacement.
Other thoughts
Overlapping coverage
Overlapped coverage is a good thing. Do you notice that the drawing shows two quarter-circle heads overlapping to cover the top-right quadrant and another two quarter-circle heads covering the lower-left quadrant? That's good. Now look at the upper-left quadrant. There's just one head covering much of that space. To keep the grass green there, ie to get enough water in that quadrant, you'd have to water until the other two quadrants become marshy.
Fix it by adding more heads. Add a half-circle head in the middle along the upper edge and another along the left edge. Finally, change that one weird little sector at the interior corner by the house to a 3/4 circle.
Choose a sprinkler model that has a throw radius about half the width of the yard. Distance can be fine-tuned for the whole system first by adjusting the pressure regulator and then by adjusting a screw on each sprinkler.
Precipitation rate
Precipitation rate is the amount of water (the depth) delivered in a period of time. It is measured just like rain in inches or millimeters or whatever per hour. Some sprinkler families are designed to deliver matched precipitation rates, and it's worthwhile to choose one that does. Often the rate is set by changing out a nozzle to control the GPM. You could use a 1 GPM nozzle in the quarter-circle heads, 2 GPM nozzle in the half-circle heads, and 3 GPM nozzle in the 3/4-circle heads (for example).
Zoning
Avoid the temptation to put too much GPM demand on a zone. If you add heads and choose the flow rates as I suggest the total demand in the turf grass would be 5*1 (1/4 heads) + 2*2 (half heads) + 1*3 (3/4 head) = 12 GPM. Divide that into three zones of 4 GPM each to avoid straining your water supply, which manifests as sprinklers not spraying as far nor as well as they should.
Water needs for shrubbery, potted plants, etc are different than for turf grass. You'll probably do well to put all of those together on a zone that does only these and no grass.
  • Thanks @Greg Hill for this is super helpful and detailed answer. As for a pressure regulator I’m not sure I’ll be able to get a plumber out here anytime soon to install a pressure regulator or second meter since the water and sewer and building department are not allowing new meter installs due to COVID. Assuming I can still legally install the system and just hook it up to my spigot do you know if something like this will suffice? amazon.com/Renator-M11-0660R-Regulator-Lead-Free-Adjustable/dp/…
    – Jordan
    May 12, 2020 at 14:26
  • The product page doesn't call out how many GPM that regulator is designed for, so it's hard to say if it would do the job. Its price is 50%-70% of a permanently installed regulator, too. If it were me I'd buy the right regulator for the long term and plumb it to the spigot with temporary means such as a hose thread adapter and cut-to-fit PVC pipe. Because the source is drinking water, make sure the backflow prevention mentioned by blacksmith37 is installed too.
    – Greg Hill
    May 12, 2020 at 17:48
  • I might suggest a vacuum break faucet may not meet your city’s requirements for back flow prevention. They do not on the community water systems I have been connected to but they are nuts in Oregon not only a back flow preventer but 24 month inspection cycle required.
    May 13, 2020 at 21:00
Usually sprinkler systems are on a second water meter so that they are billed at lower rates than water used in the house. A municipality approved anti-siphon/backflow valve will be required and may cost a couple hundred dollars. Very likely you will need a diagram for approval and a final inspection when finished. Pick a pipe size and stay with it ; I put in my own system and used both 1/2 and 3/4 pipe . So when I make repairs, I need two sizes of parts, inconvenient.
  • Thank you and also seems like good advice on the different pipe sizes, thanks! My town appears to only require approval for a new meter which unfortunately they’re not doing right now. I’ve reached out to them to see if I can still install the system in the meantime and hook up to my spigot.
    – Jordan
    May 12, 2020 at 0:26
  • Wow that would be cool but I have not heard of it for residential, I had a 30 hp pump for my farm irrigation prior to last year that was billed differently but it was not treated water.
    May 13, 2020 at 20:56
