I am trying to change the water line on my fridge, but the end connector is different. My current set-up is just the plastic tubing connecting directly into the coupler, but the replacement part under the red cap has metal fittings etc. This is the proper replacement for my fridge Fridge Water Line and this is what the end looks like Water Line End
Can I just cut this end so that it will be the plastic tubing like I need?
