How do I adjust this type of hidden door hinge so that the hinge part on the door itself gets closer to the hinge part on the door frame? I figure it's done using the two top and bottom hex screws on the door side hinge, but no matter how I screw or unscrew them the difference is unnoticeable.
It's the Italian brand Nusco.
Picture 1
I need to do this because the upper part of the door has a bigger gap when closed, as you see below, and creaking occurs.
Picture 2
  • Just to be clear, are you turning the pozidrive screws or the hex screws? May 10 '20 at 16:56
  • The hex ones. Which directions should I turn to tighten the gap? May 10 '20 at 17:38
  • I'd try counter clockwise on all 4. (Upper hinge.) They might possibly not be conventionally threaded as much as move through a range of adjustment when spun 360 degrees. May 10 '20 at 17:44
  • it looks like the left side of the hinge has a depth adjustment
    – jsotola
    May 10 '20 at 18:33
