In the process of going to add some low voltage landscape lights to an existing low voltage transformer I found out that when I touched the metal base of the transformer I got a bit of a shock. I originally figured it was something shorted in the transformer box itself but as I traced it out further to where it was connected to the outside 120v outlet that if I put my meter leads on the metal part of the outlet box and the other end directly into the ground ( the dirt) I read 120v. Kept backing up and found the same thing on 2 other patio outlets thats on the same circuit.
Im in the low voltage business so I know how to use a meter and have some knowledge of electricity but I cant figure out how I have the 120v between the metal outlet box and earth, and again, this means sticking one lead directly into the dirt near the box.
Any thoughts or advise very much appreciated.
