I am having a deck installed and question how the posts are done.
The deck is from 2 to 5 feet above ground on a slope. The holes were dug, probably 5 feet deep near the house then about 4 feet at outer edge. Inspected by county.
They had started building the deck framing on temp supports waiting for inspection, then after they mounted the post to the frame so they were suspended in the holes. Maybe 2 to 4 inches above the dirt in the bottom. Then poured about a foot of cement in bottom and filled in with dirt.
I'm worried that the bottom of the posts shouldn't be sitting in the cement ?
I've been reading they should be on a gravel base, Do I need to worry ?
Thanks
  • Welcome to Stack Exchange. You should take our tour so you know how this site operates with upvotes for helpful information and checks for accepted answers.
    – HoneyDo
    May 10 '20 at 4:25
If I understand your description you're concerned because the posts are encased in concrete with no gravel under the posts.
It would have been good to have gravel under the posts for drainage but it's not critical. Of greater concern to me is the several feet of soil they placed around the posts above the piers. Encasing the posts in concrete isn't necessarily a problem but in my opinion you want to avoid having soil directly in contact with the posts. Microbes in the soil and moisture in contact with the posts will accelerate rotting so you want to avoid that. There are various ways to anchor deck posts and provide for drainage away from the posts. I have seen deck posts done just the way yours are - it is structurally sound but I don't like it because of rot issues. Given that your piers and posts are completed I'm not sure what recourse you have. So let me show in the picture below the way I prefer to do posts and one possible remedy for your situation.
The illustration on the left is the way I prefer to do deck posts because it keeps the post above grade while still providing support. The one on the right might be one remedy for your situation. It would mean removing the soil around the posts down to the pier and then backfilling that space with stone for drainage. It's not the ideal solution but it will give the posts a longer life.
  • Thanks for the feedback. I dont think I can do anything now since they are 5 feet deep and under the deck. I'm considering whether I should put something around the posts to direct rainwater away, like a layer of plastic and rock for a foot or two around them.
    – Laura
    May 19 '20 at 11:29
  • The deck itself will provide some protection. You can't do much at this point but it's not a disaster - just not the best way to do it IMO.
    – HoneyDo
    May 19 '20 at 15:08
