I am creating a shelf in my garage to go over the front of the car.
The rules of the town home community is that we can't have anything that puts weight on the structure of the garage, so have created two by side supports designed to have something go horizontally go from one to the other ( it's 42" deep ).
I was thinking of 2 or 3 2x4's to go span the 10', and then using 1 x 4 slats over that for the shelf.
How much weight would this hold ?
Should I use 2x6's ? Should I use 2 or 3? Or ?
Not planning to put a lot of weight up there, maybe cumulative around 150 - 250 pounds.
Any thoughts on what I should use to span the 10' wide, 42" deep shelf space ?
I do not know how your side supports are constructed or how you plan to keep it from racking side to side.
Three 2" x 6" set on there side so they are like floor joists, I.E. not laying flat.
One front, one middle one back, use Simpson joist hangers to attach to side support rim joist. 1/2" Plywood decking on top of that to create a shelf.
If you want even more weight capacity overkill make it four joists.
How much weight will it hold ? There is an online sag calculator you can use https://www.woodbin.com/calcs/sagulator/
It is a garage shelf, if it sags a little over time it is not the end of the world. When it does, Turn your joists over in the joist hangers so the crown is on top and get a few more years out of them. Or use 2"x 8".
  • The issue is turning them up on their side (not laying flat), will suck up another few inches in what clearance I have from the shelf to the ceiling... what if it used sistered 2x4's not laying flat in the front and back? So a total of 4 2x4's. Would that hold 150's or so? if it sags a little, not the end of the world. I am sort of out of my element in figuring this out.
    – Jamie
    May 8, 2020 at 23:47
    They are much weaker and prone to sagging laying flat, even stacked, because of the grain of the wood. A single 2x4 on edge is better then two stacked laying flat. Use a thicker plywood for added strength.
    – Alaska Man
    May 9, 2020 at 0:02
  • If you have room below to add knee braces this will add strength and help prevent racking.
    – Alaska Man
    May 9, 2020 at 0:09
  • I will have to look up what a knee brace is....lol.
    – Jamie
    May 9, 2020 at 0:38
  • Question about bracing - diy.stackexchange.com/questions/113392/…
    – Alaska Man
    May 9, 2020 at 1:57
Given your desire to make it comparatively thin (which is bad for stiffness in general) the best bet would be a Stressed Skin Panel also known as a Torsion Box
Common construction for that as a DIY is two sheets of plywood, (one top, one bottom) and some sort of spacers plus lots of glue. It's an interesting and educational experiment to compare how two sheets of plywood separated by a foam core behave without glue when you stand on them as compared to how they behave when the core is glued in, but for a shelf you don't need foam as a core - wood will do.
What this does (compared to using several joists, unbonded) is to provide a full sheet worth of strength on the tension side of the structure - similar in principle to an I beam, where the sheets of plywood (or OSB, it IS a garage shelf...) act as the tension and compression "flanges" and the wood spacers act as the "web" that holds them apart.
However, it is STILL the case (it is ALWAYS the case...) that additional depth (space between sheets in this case) pays off hugely, because stiffness is related to the cube of the depth of a beam - so a beam twice as thick is 8 times as stiff. Or a beam merely 1.25 times as thick is nearly twice as stiff, and one 1.5 times as thick is more than 3 times as stiff as the original beam.
(A different option in the "buy a solution" direction would be to get prefabricated steel pallet racking, but I assume that if you have already built side supports you are not interested in going that direction.)
If you wish to play with loading options (this is NOT set up for stressed skins, just beams/joists): https://courses.cit.cornell.edu/arch264/calculators/example8.1/index.html
Like the good answers by Alaska Man and Ecnerwal indicate, you won't span 10 feet with flat lumber. Even if you made the platform entirely of 2x lumber it would be a trampoline. It need to be thicker (taller), and that height needs to be composed of a single ply, not layers that can slide with respect to one another.
I'd get three small-knot 4x4 posts (or four pairs of doubled 2x4 on edge), space them evenly front to back, and overlay them with 1/2" plywood or OSB. That's as thin as you'll get (4" total) with non-engineered wood and reliably carry that load. Be sure to crown all members up for best sag resistance.
  • This is what I am going to try after comments here. Hopefully this will fly. Worst case I try again after it falls apart. Have 2 x 4's in a framed square on each side for the load. Spanning it the 10 feet I have 4 2x4's on their side (long side up), 2 of them bolted and glued sistered together in the front, one in the middle, one in the back. The back one will have a 2x4 in the center as vertical support. On top of it going to use a 1/4 inch piece of plywood that will be 44" x 10 feet.
    – Jamie
    May 9, 2020 at 22:14
  • I will glue it and also nail or screw it to the 2x4's spanning the 10 feet. Question: better to use screws or nails (along with the glue) to attach the plywood to the 2x4's spanning the horizontal?
    – Jamie
  • There's no point in glue for something like this, and screws are both more secure and removable.
    May 10, 2020 at 16:05
