I'm building a new master bedroom closet. The wife wants a specific 30x80" door which requires a rough-in of 32x82. Unfortunately, the measurement from the top plate to the subfloor is 83 1/4". I'm not sure how to handle this. The jack studs for the rough-in would be 82" which would mean no top plate would fit (A 2x4 is 1.5" thick and I only have 1.25" available).
Do I just not put a top plate, make the jack stud 83 1/4" and just deal with the extra 1 1/4 at the top of the pre-hung casing? Do I try to trim the 1.5" of the top plate down to 1.25" somehow?
Greg
  • If you are building it why can you not just make the R.O. the size you need ? I.E. cut the jack studs to the length you need. OR just put a 1 x 4 ( 3/4 thick ) up against the the top plate, the remaining gap from top of door jamb will be covered by trim.
    – Alaska Man
    May 8, 2020 at 18:08
Cut a 2x4 to length and rip 1-1/4" off each side. Put those up against the top plate, one inside and one outside. The half inch hollow in between is inconsequential.
End view
 _____
|_____| <-- top wall plate
|_| |_| <-- 1-1/4" high rippers
You should be able to stack two furring strips on each side of the top plate. The one I'm looking at right now is 5/8" thick, stacked would be 1.25".
  • The one what? Do you happen to have some 5/8" plywood scrap on hand?
    May 8, 2020 at 18:33
  • @isherwood The furring strip I had.
    – JACK
    May 8, 2020 at 19:13
  • I don't know what that is. In my experience, all furring strips are custom-made. Does someone sell a product labelled "furring strip"?
    May 8, 2020 at 19:48
  • You can get them off the rack at HD. Common: 1 in. x 2 in. x 8 ft.; Actual: 0.656 in. x 1.468 in. x 96 in. so my bad, two stacked would be 1/16" too high. the one I had looked like 5'8". + to you
    – JACK
    May 8, 2020 at 20:17
    1/16" is certainly within framing tolerances. :)
    May 8, 2020 at 20:30
