This is safety glass, but it's very old glass <1994. So probably not the kind that will smash, but kite mark should tell you if it does.
I want to make a new door for my greenhouse out of it if I can, but that of course means cutting it down.
Sign up to join this communityThis is safety glass, but it's very old glass <1994. So probably not the kind that will smash, but kite mark should tell you if it does.
Safety glass is either tempered, laminated (with plastic layers for shard retention), wired with mesh, or a combination. Rarely can any of them be cut without detonation. I would not attempt it without substantial safety gear.
