Stairs into basement
I'm not sure how the skirt-board should mate into the base molding? (Is this correct?)
And most important, where should I end the vertical cut from the stair nose (see arrow below)?
The wall will just be finished smooth with a drywall corner piece and mud finishing off the wall and ceiling. I'm not planning on putting in trim at this time.
The original contractor had cut the tread too short and I thought this would be a great finish to a mistake I'm stuck with.
