I Need to move this outlet to the other stud.
My first thought was to splice new wire inside the box and move it over, BUT NEC doesn’t allow splicing in-wall if the box is not reachable/accessible.
Also, I’m not sure if NEC allows Romexs to be run between studs ( only stapled to the side )
How do I do this while remaining code complaint?
