All, thank you in advance for the help.
I am remodeling a bathroom and fall under IPC 2018 and was hoping that folks could look over the design below and let me know if this was code compliant and if follows good practice. Basically I was wondering if the proposed layout worked as a wet vent system or if I needed to open the wall and run new individual vents. Any suggestions are welcome.
photos at links below
Current Configuration - https://drive.google.com/open?id=18laXLjQdX7CR97IxsfdHEKBLSG1uoDaW
Proposed Configuration - https://drive.google.com/open?id=1oLorrhJ4ObA_jmICtfHLMOnkeN7k6Qa3
As is photo - https://drive.google.com/open?id=1SCymslJ1p0Cx1zQNjvSOqe7A5Wa7zjMW
