The overflow hole on my bathroom sink is rusting and will tend to "leak" brown rust particles into the basin when water is splashed up into the hole. Is there an easy fix here?
  • does water flow freely through the overflow or is it clogged?
    – Jasen
    May 2 '20 at 4:45
  • Is the basin steel or china?
    – Jasen
    May 2 '20 at 4:46
  • It's china, @Jasen. And I it's clogged!
    – Will
    May 2 '20 at 18:15
  • you could dry a drain plunger on the overflow, if that doesn't work you're probably going to have to diassemble the plug-hole and trap.
    – Jasen
    May 2 '20 at 21:04
