What type of shut off valve is this, and can I replace it with a quarter turn ball compression valve?
    That looks like just a standard shut off valve. And, yes, you can replace with a 1/4 turn valve - one of my favorite things to do for the house supply and all toilets. (The similar valve in my house was tucked away in the back of a under-sink cabinet, making it all but impossible to get at, much less turn particularly after 40 years of rusting.) – Jon Custer Apr 30 at 22:21
  • @JonCuster Type this up as an answer. – JACK Apr 30 at 22:23
  • ball and compression are mutually exclusive valve types – jsotola May 1 at 1:40
That is a standard sweated valve, if it is leaking they are easy to repair and much cheaper than a new valve. Most of the time a new seat (rubber seat that stops the water) and a new stem packing under the nut that holds the stem in place is all that is needed to fix a leaking valve , if it is leaking at the hose fitting that was probably over tightened , the plastic ones today break when over tightened those metal ones sometimes held but it looks like it is leaking. , replacing the valve with a 1/4 turn you will probably have to replace the hose also. I have a kit of faucet seats and valve packings / gortex rope that I got many years ago 10$ fixed probably 30 valves I still have the nice little metal box and buy rubber seats to refill you might consider a valve repair kit as looking at the age your home probably has 15+ total valves you could repair for the cost of 1 or possibly 2 new valves.
| improve this answer | |
This is a standard sweat valve. It would be easy to either cut or sweat it off. An easy replacement would be a Sharkbite quarter-turn valve that matches your hose connection.
